Description
Testometric can supply versions of their AT & CT machines suitable for testing in a horizontal mode. Applications usually involve specimens where long lengths need to be tested such as control cables, rope, cord, electrical cables etc. Machines are available with frames capable of testing specimens up to 20 metres long.
 Force Measurements
Extension Measurements
Speed Control
Load Frame
Software
