Description
Testometric produce wide frame versions of their AT and CT universal strength testing machine. They can be tailored to suit customer’s specific applications.
Force Measurements
Extension Measurements
Speed Control
Load Frame
Software
Comprehensive winTest™ Analysis universal windows software covering tensile, compression, peel, shear, tear, cyclic, creep and multi stage testing. It includes a wide range of industry standard test methods and facility to create and store an unlimited number of further test methods. There is automated storage of all test data and ease of export to other software packages such as word, excel, access and SPC systems for enhanced report generation.
